Camshafts question
  • VladaS2
    • Aug 2006
    • 185
    • Country: Yugoslavia
    Camshafts question
    Can someone tell me from which car are these?
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
    My Online Blog
    It's a 3B camshaft, 7A are marked 054 not 034
    • VladaS2
      • Aug 2006
      • 185
      Thanks Jamo! Actually I am looking for RS2 item but could not identify 034 102 G..
      My Online Blog
        Hint if you look at the inlet cam it has the gear on the end to drive the dizzy.
        ABY, AAN and ADU dont have this on the inlet as they use the hall sensor. Seller is trying it on.
        • VladaS2
          • Aug 2006
          • 185
          Jamo come to rescue help identify these!
          http://cgi.ebay.de/audi-rs2-rs-2-20v...QQcmdZViewItem
          Seller advertises as rs2 but is not sure!
          My Online Blog
          • s2dude
            • Nov 2005
            • 1631
            Both have gears on the end so going on Jamos tip they are not RS2 as it uses hall sensor on intake cam..
            3b maybe?
            • VladaS2
              • Aug 2006
              • 185
              I've seen that too! But the seller seemed so sure it was rs2 item! Thanks s2dude
              My Online Blog
                Those haven't got gears on the end S2dude.
                They look like the article hard to tell without closer pictures of the numbers.
                • ezveedub
                  • Aug 2006
                  • 19
                  He is stating that they are from a ADU RS2 motor. He states they been sitting in a garage.
                    Yes we know thats clear in the auction but without close up pictures it's hard to tell the difference between ABY and ADU cams.
                    The inlet cam is the same on the ABY and ADU anyhow it's the cam wheel that advances the RS2 by 10%..
