Just been sorting through the seemingly endless list of things to do on my car, when after cleaning off the engine block to find oil leaks I have found that one of the cam cover bolts is spinning round.
oil is weeping from the front corner (turbo side) and the corner cannot be screwed down because you can lift the bolt out with your fingers, Seems the thread from the head is still on the bolt as the thread is 'full'.
Is there a quick fix for this? or do I need to take the cover off and get something more serious done?
Thanks for any advice.
Chris
(ps, as you may be aware, I am not a mechanic, but can just about get by if told)
Chris
