Sump Plugs
  • iain1067
    • 984
    Sump Plugs
    I know a few people have struggled to remove this item when changing your oil. I was faced with a nicely messed up one on my S6 which i knew was there from previous monkey lads/owners. I had before managed to knock on a 16mm socket which had decided to fall off somewhere damn and double damn i was thinking this isn't going to easy, anyway after trying to knock another socket on (and failed) i decided to use a cut down 17mm spanner that i had in the toolbox worked a treat with a pipe on it.
    Now i usually change the oil with the engine hot, and yes the plug does seem to be glued in and previous changes had taken quite a bit of effort to get it undone, today though i hadn't started it at all and i was really surprised how easy it came undone compared to to undoing it hot.
    So if you are struggling to get the plug undone try it cold.
    Iain
  • lune
    • Jan 2005
    • 109
    I would suggest replacing OE plug with:
    A mechanical problem while driving your car along the busy roads of the city? Fumoto Valve Auto Blog is an interactive online magazine that promotes safety measures through driver education about everything that involves auto handling and operation to ensure welfare from vehicular mishaps along our roads through due to mechanical and driver error. Designed to empower car drivers with troubleshooting skills, we have been dealing with this matter for a decade with profound commitment and unmatched expertise.
    No more hassle
    • s2_bo
      • Oct 2005
      • 6067
      When worst comes to worst you can always try this method.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • iain1067
        • 984
        I usually don't have a problem, i always a long breaker bar and decent fitting socket, anyone know where to get these fumo valve thingys in the UK
        • martinjs
          • 3205
          Most people got them from the states when there was a group buy a few years ago, might be worth asking them again if there are more people interested.
          Just changed my oil this morning, forgot how easy it was with one of the valves fitted, well worth it.
            States only ask Greg S if he's sold his as he had one for sale a while ago
            • iain1067
              • 984
              Always amazes me how dirty looking the old oil is even after only 3k miles
                Ive sold the fumoto now im afraid
                • baltiboyS2
                  • 965
                  I have one spare pm me if your interested
                  Raj Aby
                  • Efini
                    • 154
                    • Home: United Kingdom Current: United States
                    Last week I undid my sump plug with the following injuries:
                    - 2 broken toe nails
                    - 1 totally missing toe nail
                    - bleeding nose
                    - cracked upper lip
                    Luckily noone saw me make a fool out of myself and the sump plug survived without a scratch.
                    • merlin's S4
                      • Jan 2005
                      • 1539
                      I bought greg's fumoto valve but I couldn't screw it on to my urS4 as the anti roll bar was in the way! Your S6 will no doubt be the same! Obviously if you don't mind removing the ARB to fit it, then that's fine but I decided to replace the sump plug and washer with each oil change and only tighten it to the specified torque!
                      However if anyone would like my Fumoto valve, then a tenner plus postage should secure it!!
                      • s2dude
                        • Nov 2005
                        • 1631
                        Pm sent
                          Merlin you need the Fumoto valve without the Nipple extension in that case i'd image.
                          • s2_bo
                            • Oct 2005
                            • 6067
                            - bleeding nose
                            - cracked upper lip
                            I hope you got the ****** off - after all that sweat blood and tears
                            91 S2 coupé - RIP
                              OUCH !
                              - bleeding nose
                              - cracked upper lip
