Hi all...
I'm trying to buy an S2, and appreciate that they are all a few years old, with high mileage, but if they have been looked after they should be fine...
I've seen one which drives well and has smooth engine etc, looks great...BUT...
The engine is splashed with oil.. it's in the little wells by the tops of the spark plugs... and a look underneath (without it on a ramp) indicates some dripping down there.
The owner says it "doesn't use much oil" which could be interpretted as meaning it DOES use oil!!!
To a niaive person like me it looked like oil was leaking from the oil filler cap.. which raised these thoughts:
- if it's just a poorly sealed filler cap, why hasn't it been replaced, as the owner has had the car fully repaired and maintained at a VW Audi garage
- A friend said the problem could be piston rings going - and the escaping compression forcing oil out of the filler cap.. which could mean a hefty engine rebuild soon?
So my questions are ....
- Does this piston ring theory sound possible... and if so whats the maximum damage - my mate thinks if it causes serious piston/cylinder damage in time, it could costs thousands.
- Is there any way to check if the piston rings are OK ...(other than dismantling the engine which presumably will cost hundreds in labour???
Other clues:
There's no under engine protective panel ..shouldn't there be one?
The trip computer gave 20mpg average on a 10 mile run round country roads...we never hammered it, but were up and down the gears.. I guess this is about right??
The car has acres of history, and has had plenty spent on it every time something needed doing, all at one VW-Audi garage.
Thanks for any help you can offer
Phil
Other clues:
Phil
