Brake light code..
  • audi660
    • Jan 2005
    • 162
    • Country: South Africa
    Brake light code..
    Can anyone help me with this problem?
    Getting "Brake light switch-F - impluasible signal" code on the VAG.
    If I clear it, it keeps coming up.
    What does this mean?
    [SIGPIC]1997 Ur-S6 SMS Revo S
  • Dan_s2_coupe
    • Aug 2006
    • 482
    its a common fault, if the brake lights are workin it is the part of the switch 4 the ecu, you will have 2 check is its 2 or 4 pin aswell
    • audi660
      • Jan 2005
      • 162
      Could you pls tell me where the brake light switch is located and what colour and size it is?
      Thanx
