Advice/Help Needed
  • ian_jemo
    • Aug 2004
    • 284
    Advice/Help Needed
    Hi all
    Just had a few quick questions, I hope
    1. When I turn my car off the WGFV ticks for about 5 seconds, Is this normal?
    2. Where can I get a pressure testing kit from?
    3. Is a pressure testing kit easy to make?
    4. Thinking about taking my car to MRC to get it chipped, will MRC look over the car for you to ensure it is running right?
    At the moment it feels like my car is running at low boost for some reason? When at full throttle the car just doesn't feel right its only until I drop it in to gear it feels like it gains some power. Does anyone know what this could be, I was presuming it could be a boost leak?
    Thanks Ian
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    Yes, MRC will give the car a health check if you ask them to. Will be doing the same with mine once ready for the re-map.
    Old Stuff Reborn.
    • s2dude
      • Nov 2005
      • 1631
      Originally posted by ian_jemo
      Hi all
      Thanks Ian
      Pm forum member Andy P for a pressure testing kit......only about £20 iirc
      MRC will look over your car AND fix any problems before they map it....(may not be in with mapping price though)
      • ian_jemo
        • Aug 2004
        • 284
        cheers for that might see if I can get booked in. Does anyone know if MRC are busy at the moment?
        • ericd
          • Nov 2003
          • 1240
          I'm sure MRC will be pretty busy, why not try and get yourself up to Billing ???(you might find or or two of them there), or they'll be a few others that'll be there and somebody will have a leak kit..
          • ian_jemo
            • Aug 2004
            • 284
            Ok cheers, I might give MRC a ring to check there availability
            My car feels like the power/boost is restricted, The engine runs really smooth and nothing seems a miss its just there is no power when at full throttle.
            My car was running right before I changed the MAF hose to a new Samco one, While I was changing the hose I found that both vacuum hoses from the WGFV to the turbo & wastegate were ripped but I don't understand why it was running so good with these ripped. I have know placed all the hoses on securly and I'm about 99% sure I haven't got any boost leaks.
            I'm only guessing but not to sure I think its something to do with the wastegate, I have heard that the car can run at mechanical boost at that is what it fills like. It fills like it is running at a limited amount power.
            Does anyone know what can cause this problem?? I really want to get my car running good before taken to MRC plus It will save me time to get there as well.
            Ian
