Can ECU understand the quantity of air which is going to cylinder? With different turbo goes different quantity of air to the cylinder. Let’s compare K24 and RS2 (K24/7200). K24/7200 produces less air at low rpm than K24. Let’s say that I’m using K24 stage1 software with RS2 turbo. Is that software able to take into consideration that there’s not so much air at low rpm and then there’s no need to make air/fuel mixture so rich?
Same questions about ignition angle!?
And please, answer only if you know what you’re talking about..
Thanx,
Marko
Thanx,
Marko
