ARReee, now my ABY cutt off again.....
  • s2avantdk
    • Mar 2006
    • 49
    • Country: Denmark
    now my S2 avant ABY doing the small bump in aceleration an cutt off to.
    i have don the Mark O-ring, an the N75 is new, an clean my MAF an so on,
    butt i dont now what to do now, take the car into a tre...........:mischeif:
  • Bjoern
    • Jan 2006
    • 35
    • Country: Denmark
    Please help me. My S2 '94 do the same. It goes nice a week or two and then it begin with the small jerk and then at the next acceleration i cutt at full speed. After that it cutt with about 0,4 bar. I know s2avantdk and his and mine car have exactly the samme fault.
    • Knight Rider S4
      • 3541
      Do a search on Hall sender .....sounds like your problem (both of you)
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • Bjoern
        • Jan 2006
        • 35
        • Country: Denmark
        The Hall sender is changed on the '95 Without any change.
          It's sounds like a boost leak and overboost protection but my betting is on the knock sensors, they need replacing.
          Hall sensor wouldn't cause these sympthons, he would have problems starting and if it did fail during the engine running the ecu would still keep the engine running and use the crank sensor.
