Hi, what I have to do with the valve and the black tank? disconnect it?
Catch tank fitted
Could it not be done so it remains standard with a catch tacnk in place especially on the ABY/ADU which has the output on the side of the cam cover? SO in theory the sludge is catched in the tank and the fumes go throught the cam cover to the turbo (which I am presuming is the way it happen stock).
AzDark Grey Avant
RS2 FARB
Alloy Subframe BushesComment
IIRC then the 3B and RR have a small pressure output tapped into the rear of the camcover anyway (I remember having to do it to my 7A cover) therefore a larger one could be tapped there and another one on the side to be essentially the output from teh PCV system straight into the inlet again, should be a reduced sludge intake which is good (or am I just being thick here guys, feel free to shout at me)Dark Grey Avant
RS2 FARB
