250 KPA mapsensor on 3B (200 KPA std)?
  • 1975DCS
    • Sep 2006
    • 258
    Yesterday I learnd that the ABY uses a 250 KPA mapsensor, which of course has the possibility to read to 1.5 bar boost pressure and therefore the ABY has a stronger overboost at mid RPM. That make me wonder if there are simple plug and go chips available for the 3B so I too can enjoy this midrange.
    I currently use a 270/280 bhp chip, with overboost (safely) limited to 1.1-1.2 bar...
  • s2carlo
    • 252
    why not swap pressure sensor for 25okpa one?
    Mihnea did it on mine, works perfect
    No power, no glory!
    S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
    • 1975DCS
      • Sep 2006
      • 258
      If I change to a 250 KPA I would need a remap because the current chip cannot work with the new data as Voltage versus KPA are different... If there is no ready chip available I would need a custom build remap...
        There are generic 3B chipsets available for 250kPa - ask Mihnea @ MRC
