Slow temp rise
    Slow temp rise
    The Avant is terribley slow to warm up in comparison to the Coupe.
    When i was bleeding the system it took the car nearly 40 minutes to reach 90c where as the Coupe did it in about 10 both sat on the drive.
    Recommendations? New thermostat and any particular sensors?
  • Jon441cc
    • Dec 2005
    • 2061
    Could well be the thermostat, Did you say it was running rich on the dyno?
      It was so rich the car was blinging, i'm sure i heard the engine bay singing get rich or blow a boost hose trying
      • Nuvo
        • Nov 2003
        • 3825
        I don't think a rich condtion is likely to cause pinging not to mention "blinging" whatever that might be A lean AFR is more likely to cause knock or ping isn't it?
        • rotoryboy
          • May 2004
          • 3281
          That's you all over mate, the king of Bling
          Mark
          Race Clio RS197
          S2 Coupe ABY (Green) - RIP
          S2 Coupe ABY (Blue) - Sold
          • Rusty
            • 18953
            Thermostat - what does it run at when cruising down the Mway at 70/80? My coupe used to drop to 70 in the winter. New thermostat and coolant sorted that out. Is it running the extra radiator and the coupe wasn't? (That could quite obviously make a difference).
              Originally it wasn't running the aux rad as it had burst so i had it blanked off.
              It was still very slow then it got slower with the aux rad which i expected.
              I'll replace the thermostat.
                Everyones favourite job - NOT !
                • dan_b
                  • Sep 2003
                  • 3670
                  Having the aux rad back in will make a big difference in warm-up rate, also sounds like the 'stat is suspect. What about the MTFS, that could be fubarred as well? All your favourite jobs!
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Sounds like a stat stuck open to me...
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                    • volcano rs
                      • Jun 2005
                      • 2265
                      put a winter stat in i know some cars have 2 types one for winter one for summer
                        Waste of time IMO
                        • phil2.016v
                          • Mar 2006
                          • 300
                          I've had a similar issue with mine, it never seem to run at more than 60 on the gauge, until I replaced the main rad, which caused the rear housing to crack due to increased pressure, I've replaced that today and discovered that the head gasket has blown!!!
                          Hopefully, you aint got the same problem!
                          Audi 80 2.0
                          E21 BMW 316
                          Ibiza Cupra Sport
                          Mk3 Golf GTI colour Concept in black!
                          Mk3 Golf GTI
                          VW Caddy van with my gottis on it
                          • 1975DCS
                            • Sep 2006
                            • 258
                            Which rear housing? And which increased pressure? (some explanation asked by a beginner...)
                            • iain1067
                              • 984
                              Thermostat is the likely choice, i think every audi i have owned has needed that, they don't last that long either 2 years and it's time to do it again.
                              Iain
