I’m building a new engine and want to use relay strong components. What brand crankshaft accessories do You use ? I'm specialy interested in crankshaft bearings. But alsow in:
26 is connecting rod bearing shell yellow/violet
24 is thrust washers bearing 4
23 is bush - connecting rod
25 is crankshaft bearings
My goal is 550KM and want to build really strong base for it. I will use a new line of Garrett turbos a model called GT35R (GT35/40) turbo for it
What needs to be changed in cylinder block to make it sufficient for that power and maybe more if I use Nitro later on.
