fuel pumps ... more HP but what will pump the fuel ? new GT35/40 turbo problem
  • Albert
    • 1500
    • Country: Poland
    We have just got new big turbo form Garrett and we are pretty sure that RS2 fuel pump wont provide the proper amount of fuel. For the power that we are going to we need about 170l/min
    What is the RS2 fuel pump efficiency ? and at what kPa ?
    If You use other pumps please share the knowledge
    AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
  • Mark Halligan
    • 2001
    Hi,
    Doug and I have installed, Bosch P# 0580 254 044.
    Specs are: 200 l/h fuel delivery at 5 bar pressure, Bosch page here .
    You also need to install it in a different reservoir mount, Audi P# W895 201 779H along with the bottom half/strainer P#895 201 531A.
    Full details can be found in Doug's 420+bhp project .
    Although don't use the pressure damper as it appears to be the wrong one, a 12x1.5mm Dome nut does the job nicely.
    Cheers,
    Mark.
    Mark - Modded
    • Floddy
      • Dec 2003
      • 222
      Any info about how far the 044 pump will go in HP?
      Red cars are the fastest ones...
      - Team Irry -
      • Mark Halligan
        • 2001
        Floddy,
        Its supposed to be good for around 600 bhp.
        Cheers,
        Mark.
        Mark - Modded
        • Floddy
          • Dec 2003
          • 222
          Ok, thanks.
          I'm having some ideas about how my fuel system will look like. A system with one in-tank pump, a catch tank and an external pump. Want it to be enough for 600hp + safety margins. Not saying that I'm going to get my engine cranked up to 600hp, but IF i reach that sometime in the future, I don't want to rebuild the fuelsystem again.
          My idea now is that perhaps i can use one 044 in-tank to feed the catch, and one 044 external from the catch to feed the engine?
          - Team Irry -
          • Mark Halligan
            • 2001
            Yep, that sounds like a good idea this uses two 044 bosch pumps.
            The nice thing about these pumps is that they can be mounted in the tank or externally.
            Cheers,
            Mark.
            Mark - Modded
            • Floddy
              • Dec 2003
              • 222
              807hp!
              But from what I see that one uses two parallel 044's?
              - Team Irry -
              • Mark Halligan
                • 2001
                Another link showing power rating (although picture is wrong).
                Cheers,
                Mark.
                Mark - Modded
                • Floddy
                  • Dec 2003
                  • 222
                  "the BIG MAMA of fuel pumps!"
                  - Team Irry -
                  • Mark Halligan
                    • 2001
                    Yep ,
                    the first post in this link reckons its good for 700bhp :eek2: .
                    Its a good one .
                    Cheers,
                    Mark.
                    Mark - Modded
                    • audiman
                      • 4827
                      All depends on BHP. I have the stock S2 pump and it copes fine. Thats with RS2 injectors and a 4bar pressure reg. @1.8 bar boost
                      Tom C - www.rcmr.co.uk
                      Audi UR Quattro
                      Audi 100 C3 2.0 5 cyl 115ps
                      Audi B5 RS4 645ps 911nm
                        You also want to be careful that you are not pumping too much fuel. If you do that all that will happen is it will keep getting returned to the tank all the while so you are better not going way OTT on it.
                        just my 2p worth
                        • Tote
                          • 13
                          Originally posted by Floddy
                          Ok, thanks.
                          You don't need an 044 to feed the catch tank, you should have a lowpressure pump before it, and then the 044 after it.
                          Do you need the instructionin english or can we take in swedish?
                          Make a forum on irry an I'll tell you more about how your fuelsystem should be built :nana:
                          /Tote
                          www.irry.com
                          • Mihnea
                            • 1288
                            Just one thing to notice, doing 600 reliable HP on a 2.2 liter engine is simply not possible. anything above 500 will require extensive and regular maintenance and rebuilds, no matter how over-engineered your engine and its internals are.
                            The problem with that isn't fuel or ignition, engine management or air supply but rather the heat such amounts of HP produce. The Audi 90 IMSA was using special head castings in order to produce 700 HP between 6500 and 8500 RPM with a peak at 730 somewhere around 7500 RPM, but yet it required so frequent rebuilds that it can be in no way considered as a reliable engine.
                            I know of some guys running 530+ HP in Germany and who rebuild their engines every 2 months or so... this is in no way meant to discourage any of you, but quite frankly, for my own car, I won't ever go past 450-470 HP simply because I'm sure I won't have the time, money, nor the will to rebuild my engine even every year or so....
                            The day I want 600+ BHP, I'll get myself an RS4 and start poking around it, stuff some nice goodies and make it produce 650-700 HP, which is still somehow more reliable than an IMSA engine...
                            Just a thought,
                            Mihnea
                            www.MRCTuning.com
                            info@MRCTuning.com
                            Workshop Directions
                            • Floddy
                              • Dec 2003
                              • 222
                              Yeah, I had a discussion with Zap on this, and came to the conclusion that the stock fuel pump would probably be enough to fill up the catch, if your'e not running the 044 at 100% for more than a minute or so...
                              - Team Irry -
