ABY transplant into 3b?
  • Greenm3
    • Jul 2004
    • 512
    As the title syas what is involved in this? My enigne is completely dead neads a full rebuild but i plan to upgrade it but for now i need an engine in my car to use it and the only complete engine i can find is and ABY.
    Am i right in thinking i need a wiring hraness, ecu and enigne, but what about mating it up to my 5spd box? and battery placement etc.
    Any help appreciated
    Michael
  • Greenm3
    • Jul 2004
    • 512
    Of course that is unless anyone has a 3B lump sitting about? Just the bottom end would do cause i can get the head sorted anyways. Please anyone with anything, it's been over a year since ive driven the car and I need to get the car back on the road!!!!
    • rotoryboy
      • May 2004
      • 3281
      You tried Sal?
      Mark
      Race Clio RS197
      S2 Coupe ABY (Green) - RIP
      S2 Coupe ABY (Blue) - Sold
      • mcandmar
        • Apr 2004
        • 5118
        You have a few options,
        1) use the aby block with your 3b head, flywheel and crank pully. Just a bolt together job, only catch is you should balance the bottom end if your changing flywheel from another engine.
        2) Complete aby setup with head, coilpacks etc. That would require ecu, wiring loom etc.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
          Its a pretty major job going from 3B to ABY... Option 1 above is the path of least pain - and I'll bet mcandmar has made an offer for the ABY head in that case ! LOL
          If going Option 1 then deffo keep the 3B flywheel - its lighter and will work best with your 3B clutch and 01A gearbox with no further mods... But yes it is worth getting it properly balanced...
          Paul
          • DJ-ROY
            • Dec 2004
            • 710
            I did the 3b >ADU conversion
            it really hurts
            RS for ‘Rennsport’ - ‘Motorsport’ in German
            • mcandmar
              • Apr 2004
              • 5118
              That was option 3 :mischeif:
              • aelred
                • Jan 2005
                • 761
                Steve, with the red S2 at Castle Combe has a complete ABY engine for sale from an avant still in the car so it can be heard running. He is not a forum member but if interested I can forward details and contact number.
                Aelred
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  Or use the engine and go standalone ecu on it, coil per cylinder and all the benefit's but you can map it yourself should you wish.
                  Corey
                  01636 822288
                  • Greenm3
                    • Jul 2004
                    • 512
                    Hmmmm a few options then, though will have to look at the costs of each as at the moment i just want the car running and i will use my old engine for a project. Thanks for all the help.
                    Will let you know how i get on and depending on my bank manager.
                    Mike
                    • WabTheKing
                      • May 2004
                      • 2567
                      i have 7A block if that is of any use to you, might even have a full bottom end actually
