Hello friends.
I need the electric scheme the MAP of ECU of a Audi S2-3b.
Is for a friend whom to change by the 300 kpa and needs the electric scheme.
Thanks
Its pretty straightforward... max output from MAP sensor is 4.8V - divide that by the dynamic range (200, 250 or 300 kPA) to get the absolute pressure per volt.
In short its -
2.40V per bar on the 200kPa
1.92V per bar on the 250kPa
1.60V per bar on the 300kPa
Those are ABSOLUTE pressure values i.e Ambient plus Boost pressure
