3B ECU on AAN
  • s420vq
    • Jan 2006
    • 15
    • Country: South Africa
    3B ECU on AAN
    Will a 3B motronics ECU work on a S6 with AAN engine?
  • iain1067
    • 984
    i wouldn't have thought so 3b uses a distributor and the aan isn't
    Iain
    • s420vq
      • Jan 2006
      • 15
      Ian my own S4 has an AAN engine and still has the distributer (CPS) with a Hall sensor
        This won't work... AAN engine has direct ignition system. 3B has single coil and mechanical distributor. Neither ECU is interchangeable with either engine.
        • s420vq
          • Jan 2006
          • 15
          Thank-you for the info
