Lee,
Did your measurements from the centre of the crank to the centre of the stub mounts is 184mm. There snub mount sticks out 10mm further than the front face of the crank pulleys.
I started bending tools so gave up after 150Nm + 90degree. it only started bending when I was jumping on the end of the extension - that is 16 Stone on the end!
