how mouch bosst
  • s2avantdk
    • Mar 2006
    • 49
    • Country: Denmark
    how mouch bosst
    her.
    hov many bar shull my standart S2 ABY bost around 3500 rpm. in 6 gear.
    when it bost 0,8 it drive okay. higher will have small bump in aceleration, an about 1 Bar. it will cutt off.
    any whon have a skema or somthing. ???? over the bosst in defrent gear an rpm. ???
    i think my wasse gate is dead. it cant not regula the bosst so godt.
  • GT500
    • Jun 2006
    • 2181
    Sounds like split hose, air leak.
    Do an inlet pressure test.
    Rob..
    87 UR 20v ABY
    97 S6 Avant
      Air leak !
      • s2avantdk
        • Mar 2006
        • 49
        • Country: Denmark
        air leak.... but wer. ??? my O-ring is new. and a silikone hose is put on it to.
        and i have check al my hoses.
        and it drive ok the most off time. that why i wont 2 now the bosst.
        the over bosst is 1,1 bar ca. and the car do that from small rpm. but it not regular it down again. an then it cutt off. so is my 0,8 ok about 3500 rpm. or shutt it be higher. ???
        • s2avantdk
          • Mar 2006
          • 49
          • Country: Denmark
          hey. after a little sech. i maby think it cut be my F96.
          wath do you say. S2central......
          i have read this tread.
            Could be that, but I'd go after an air leak 1st...
            Paul
            • s2avantdk
              • Mar 2006
              • 49
              • Country: Denmark
              i have check it al. ant the car is runing tomgang... an so on ok. so i dont think its air leak, its only somtime its can regular the bost presure
                Standard ABY is 0.8bar boost maximum - except in overboost mode when you should see 1.1-1.2bar in 4th or higher from low engine speed when the throttle is floored quickly. This max boost starts to tail off from about 4000-4500rpm.
                If you are certain you have no leaks then either the car isn't reliably getting into overboost mode (have you checked TPS resistance values at WOT), or your WGFV (N75) is slow/old and you cannot achieve the target pressure.
                Paul
                  Oh also - RESET the ECU by removing it for a minute to clear any existing fault codes before making any more changes... Or you can use VAG-COM if you have it.
                  Paul
                  • s2avantdk
                    • Mar 2006
                    • 49
                    • Country: Denmark
                    the N57 is new, an when it do the cut off. it go away after turn off the car.
                    what is the TPS. ???
                    • s2avantdk
                      • Mar 2006
                      • 49
                      • Country: Denmark
                      now i have by a new MAF, and change it. and now it drive alot better then befor. so i hope the problem is ok now.
