Hi all,
Will need to rebalance the crankshaft+flywheel+beltpulley assembly soon.
Main reasons are:
1) I'm using the 95.5mm stroke crank with the ABY-ADU type twin mass flywheel;
2) I'll be using different from OEM conrods and pistons thus changing both the rotating and alternating masses.
Anybody knows how to compute bobweight masses for the IL5 ?
Thanks
Marco
P.S. Contrary to my expectations, the AAT (Tdi) flywheel is lighter than the ABY-ADU one of around 2 Kg !!
Main reasons are:
Thanks
Marco
