Coil connector
  • Bjoern
    • Jan 2006
    • 35
    • Country: Denmark
    Coil connector
    Is there any way to test the coil connector for leak. my S2 Avant ABY?
    Bjoern
  • Bjoern
    • Jan 2006
    • 35
    • Country: Denmark
    HELP Please!
    • BRY
      • 3755
      Search for "coilpack"
      Happy reading
      Edited
      • caterpillar
        • 2480
        @ bry: no terms of the object.........??
          You can measure the resistance of the coil between one another. It shouldnt be huge, about 100-200ohms from memory. testing the coil is a little more difficult.
          • Bjoern
            • Jan 2006
            • 35
            • Country: Denmark
            Thanks Greg.
            I have tested resistance on the connector. It is 5 k ohms. +/-
            That i want to know is, are the eny sparks flying around. It is impossible to see. Today I found a little krack in one of the connectors.
            I wrapt a bit of tinfoil around and seal it with shrink flex. I think i´m get rid of the small jerk i feel from the car.
            So now i order 5 new one.
            I post another thread with an experience i also have today.
            I will bee back. Have to see FIA WTCC now.
              Originally posted by Bjoern
              Thanks Greg.
              How does the resistance compare with the other connectors?
              When you lift the connector off the coil and take the coils off the top of the head just get a spark plug socket extension on a torque wrench and make sure the spark plugs are tightened correctly.
              BTW the reason you couldn't delete your post was probably because it was over the editing time limit
              • Bjoern
                • Jan 2006
                • 35
                • Country: Denmark
                The resistance is the same +/- 5 % for all. The spark plugs is tighten up and only 5000 km. old.
                I think the tin foil help. I will buy some new connectors.
                Thank you.
                  Yeah I had to get some new ones for mine too, worked out at about £125 for 5
