I have noticed recently that the tub has started to use more oil than it ever used to! More than likely my fault for increasing the boost at high mileage! Anyways, back to the problem.
I think its the turbo gone, the reason behind this is that If it was bottom end then it would smoke under acceleration.
My car doesnt do that, it only smokes on start up first thing in the morning. And its quite bad. Im fairly sure its not the top end as I have done the VS oil seals when the head gasket failed, and the guides were good.
So that only leaves the turbo. Its warranty runs out 27 Feb, so time is not on my side for once!! They claim the turbo can run upto 2 bar, so im assuming that the warranty will cover this? Will have to phone then tomorrow.
If anyone has any other thoughts on this? There is also a lot of oil in the intake tracts too. So it could be worn rings?
Some days mine does the huge puff of smoke on start up but i do know my turbo is worn and my stem seals need doing
ops:
And i know where it all is still! Its on the rear spoiler and on the floorpan, not to mention the road next to work....... God its worse than i thought
