rs2 fuel pump
  • peter
    • Dec 2004
    • 96
    rs2 fuel pump
    help!i have the pierburg pump for an rs2,does anyone know what thread size the outlet is and were to get a normal banjo and bolt to go to rubber hose(not using the damper),probably been posted before but i cant find it.
  • pastures16
    • 2058
    thought the pump was inside the tank same as s2
    94 s2 avant
    aoc member 1116
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      I made a dome nut to replace the damper on my Bosch 044. It was M12x1.50 IIRC.
      SS
      • |Maku|
        • Apr 2005
        • 248
        • Home: Estonia
        A PICTURE of ADU fuel pump. Another should be from AAN.
        • |Maku|
          • Apr 2005
          • 248
          • Home: Estonia
          Can anyone tell me how much horsepower can RS2 fuel pump support?
          • |Maku|
            • Apr 2005
            • 248
            • Home: Estonia
            Anybody?
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              it can support up to 400hp,but more than that it may be unsafe
              • Audi-Porsche Avant RS2
                • Sep 2008
                • 1041
                • Country: Italy
                Hello, the original fuel pump of the RS2 is made by Pierburg or by Bosch? Thanks a lot!
                Bye
                My life and my loves
                Audi S6 C4 ABT Avant
                Audi S2 Coupe ABY
                Audi S2 Avant
                Audi Cabriolet 2.0E
                • Bubbel
                  • May 2008
                  • 28
                  • Home: Spain Current: Germany
                  Both
                  • |Maku|
                    • Apr 2005
                    • 248
                    • Home: Estonia
                    Are you sure? RS2 pump is 3cm longer than AANs pump.
                      • Sep 2008
                      • 1041
                      • Country: Italy
                      Hello, which fuel pump can I mount on a RS2 without modify? Only the original one? Thanks a lot!
                      Alessio
                      Audi S2 Coupe ABY
                      Audi S2 Avant
                      Audi Cabriolet 2.0E
                        • Sep 2008
                        • 1041
                        • Country: Italy
                        Hello, do you think that the original fuel pump of the RS2 is good for a RS2 with all original parts except for the chips of the ECU that have a overboost pressure of about 1,7 bar or not? And what about the original 3,8 bar FPR and the original injectors? Thanks a lot!
                        Bye
                        Alessio
                        Audi S2 Coupe ABY
                        Audi S2 Avant
                        Audi Cabriolet 2.0E
