Exhaust manifold gasket? Flange pattern needed please?
  • s2dude
    • Nov 2005
    • 1631
    Originally posted by WabTheKing
    i laser cut a bracket to pic up on two of the bolts on the turbo for pembo's
    probably still got the file somewhere, will have a look if you want, was only mild steel mind you, my machine wont cut stainless that thick so i have to get most stainless stuff done out
    Sounds good Wab.Mild steel would be ok..I will be coating it anyway most likely.
    Can you pm me with the details m8? cheers
    • s2dude
      • Nov 2005
      • 1631
      Well.. the manifold fits perfectly after testing it on an spare engine at a forum members house (Cheers Jamil )
      it turns out it was the manifold gasket that had a hole or two slightly out of alignment. Easily sortable with a file so Im well impressed with it for the money
