oil oil which oil to use!!!!
  • Fat Audi 80
    • 10547
    Silkolene Pro-s 10w50 for me. I was on Castrol 10w60 but was advised that it is a little too thick.
    Read the threads and go with the oil that you feel most comfortable with based on the spec of the car.
    I have to add that Oilman (Opie oils) has posted some very technical explanations and seems to know his onions.
    I would also recommend you do go fully synthetic (and one of the brands mentioned in the main threads) especially if you are chipped or going for a bit of extra power.
    The oil has to work as a heat sink too, and the more power you have the more heat needs to be dissipated....
    Cheers,
    Steve.
    The Perfectionist
    • alg
      • Apr 2004
      • 1160
      Originally posted by Corey
      Synta Gold for years, changed regularly.
      We use it in the workshop also unless a customer has a specific requirement.
      I did as well but a couple of years back it got thinner IIRC (0-40w instead of 5-40w ?) and I started to use oil between changes.
      Switched to Motul 5-40w, now 10-40w with less oil use, smoother engine, ? better economy.
      I think you will find all the threads can be summarised as follows
      Ideally use a fully synthetic
      10-40/50w
      Change it on a regular basis (6k/6monthly)
      New OEM filter/sump washer each time
      Keep a regular check on levels (once a week)
      and that would make a very easy on the eye sticky
      Alastair
      RS2
        The Avant currently uses 5W40 my old Coupe (S2Ian) has Silkolene Pro-s 10w50 in it.
        Think i'll be switching next change although tht 5W40 does suit the cars journies.
