Engine mount???
  • Dan_s2_coupe
    • Aug 2006
    • 482
    Engine mount???
    Eversince i have had my car when i let off the throttle quick there is a jolt and even if i lift of slow u can feel it its seems 2 be then the engine is not pullin so when it gots 2 over run the worse is when ur in 6th let off it jolts its wierd its asif the throttle cuttin engine
    Is this how they are or ne1 no of a problem
  • Chris5044
    • Feb 2005
    • 1663
    i find this too ..
    • martinjs
      • 3205
      Sounds like surging, are you using an aftermarket dump valve?
      I used to get this problem sometimes, if the spring in the dv is too stiff.
      • Dan_s2_coupe
        • Aug 2006
        • 482
        Yeah it an after market 1 but have wound it out so is weaker so it flutters
        • Chris5044
          • Feb 2005
          • 1663
          whoops .. maybe i was wrong .. i do get some play tho somethings .. i need to renew some of the suspension me thinks
