Forge dv worng way or right way.
  • terrybullwon
    • Mar 2006
    • 8782
    Found this in a past thread but i couldnt come to the conclusion i needed....
    I started to fit the samcos today and its never as easy as you think
    I found more things to replace ie heat sheild and this 90deg pipe thats plastic and feeds to the dv.... any how cost £4.00 behere tomoro. The heat plate i made my self
    Any how i cant remember which way i had the dv on the new hoses just made it look wierd, When it was on i would get waste gate chater i think it was this way..
    Chef
  • blown_vr6
    • Apr 2005
    • 406
    The way you have it is correct.
    The pressure is acting directly against the piston/diaphram in the same direction.
    You can however mount them in the opposite direction - from memory it gives a quieter dump
    'If you ain't broke it you ain't trying hard enough'
    Oh sh*t i broke it
    94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
    • Jon441cc
      • Dec 2005
      • 2061
      Where did you get that pic James :mischeif:
      • Davidsinclair05
        • Nov 2006
        • 365
        Can you supply a diagram of how to fit a DV
        • Davidsinclair05
          • Nov 2006
          • 365
          Sorry on a 3B 1991 j plate
          • Jon441cc
            • Dec 2005
            • 2061
            http://www.s2forum.com/forum/attachm...1&d=1135599198
            • terrybullwon
              • Mar 2006
              • 8782
              sorry jon
              Chef
              • Chris5044
                • Feb 2005
                • 1663
                if u fit it in reverse it makes a unique sound rather like a dolphin squeek ... i like it .. hence why mine makes that sound .. good at night with temp low too
                  You can fit it the other way round, there's pro's and cons for either way. My Coupe ran sh*t with it the wrong way round surged too much. The Avant came with it reversed and it's fine although i'm planning on changing it round to see what difference it makes.
                  Also makes a difference if you have piston or diaphram DV.
                  There's a big thread on the forum with dump valve reviews and a technical review showing how reversing the DV affects pressure holding. In some case it was better to have it reversed.
                  Easiest way to remember which way is correct when looking from front of car, nipple to left is the correct, nipple facing up is wrong.
