Differences in vibration dampers
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    034105251A
    034105251M
    Bottom code is from the rs2. Top for pretty much the rest of the 5cyl engines. Anyone knows what the difference is?
    M is for ABY / ADU - it has the multi-rib pulley for the 120A alternator
    The other "small chassis" damper / pulley is all vee-belt arrangement.
    HTH
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      Is that multi rib pulley the extra metal part that connects on the vibration damper or is it made in one unit?
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        This is the part number for the extra pulley 054105255E
        Can you fit the 3b damper on the 2nd part ?
        • jade
          • Jan 2005
          • 1811
          HTH
          Could you not just change the pulley on the Alternator ? as the ABY ADU pulley is N/A
          RS 2 580HP
          • mcandmar
            • Apr 2004
            • 5118
            Nope, its a completely different unit and mounting bolt. Its also much heavier as its paired with the dual mass flywheels.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • mcandmar
              • Apr 2004
              • 5118
              I tried that and the short answer is no as the ABY pulley didn't align properly on the 3B style alternator and vice versa.
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                Ah i see guys.
                So I put myself down for the fluidampr but if there is an aby/adu out there for sale let me know
                  I have a line on a repair if you have an issue with your RS2 one?
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    I'm looking for a 2nd one Alex, but I'll take your offer when I find one do get it sorted
                    • jade
                      • Jan 2005
                      • 1811
                      Same I have been looking for a while.... this N/A ....Audi thing is becoming very boring, as Now i have a car that I cannot use most of the time as I cannot find the most basic parts
                      RS 2 580HP
