Hi, i curious if somebody notieced any problems with high rpm boost on mid sized turbo/hybrid - small sized turbine side and 7A or similar higher lift cams. I feel problems over 6000rpm when my GT2871r, .63 T3 housing boosting over 1.3bar (400bhp+ power on 2.5 stroker, 10mm lift solid lifter cams). I notieced power curve starts to drop here on cca half off dyno pulls during tuning , also on streets is instantly notiecable. I have similar problem on another non audi car, and its caused due high backpressure in manifold and exhaust valves starts to float. I reduced boost around 1.2bar and feels smooth eg more power on top now.
Sounds real?
Sounds real?
Do some calcs and see where you are on the chart, as Andy says you will find you are off past the choke line.
