woodruff key part no. N0127082 ???
  • woodruff key part no. N0127082 ???
    On drawing it is part no. 4 (OEM part no. N0127082)
    what for it is used ? how it is used ? when ???
    Simply locates & holds cam wheel to cam shaft when bolts holds it all together. The rounded side sits in the cam flat edge in wheel .
      Probably correct for some cam sprockets but not true for the AAN/ABY/ADUs (and maybe the 3B??) because the cam sprocket has a built-in "key" that fits into a groove in the end of the camshaft.
        Some better photos:
          ookeyyyy , so this is the one .. ... strange that ETKA shows this thingy as separate part for ADU !
          Tommi's Billet AD001 cam sprocket has a built-in "key" as well (if I remember correctly I didn't have to fit it separately ...)
            be careful not to overtighten or pressurise the pulley wheel. the key is like cheese on aby wheels. I have broken a couple in my time.
              ... what about hexagon bolt M10X1,25X30 (no.6 on diagram, part no.: N90256202) and washer (no.7 on same diagram, part no.: 027109143) - seems that these are special ones and
              only OEM can be used
              https://www.ecstuning.com/b-genuine-...ach/n90256202/
              https://www.ecstuning.com/b-genuine-...ach/027109143/
                Could this be for the chain sprocket? At least it looks like that one.
