hey all... im doing my b2 20vt swap. what size hose do i need to go from the intake manifold to the ecu? rubber? harder plastic? please school me folks! thanks...
what size/type of hose for ecu map?
Tags: None
The original hose is a hardline made out of some type of plastic with rubber joiners. It's approximately 2-3mm inside diameter, Silicon hose will do the job. Get the correct size to fit snugly on the ECU and manifold fittings. Can't remember whether mine is 2mm or 3mm.91 Modded 3B
14 A6 Avant Black Edition -
