Crank trigger options
  • adampug11
    • Sep 2017
    • 85
    Hi all, just about to order the rear main seal with the 60-2 trigger in. What’s the general consensus on these?
    I plan on running maxx ecu on my 3B
    cheers
    Adam
    Tried & tested. Plenty of people using this system, Maxx has a config for this trigger decoder too. I just fitted one on my engine the other day (also Maxx setup) and I made a little installation tool you can borrow if you like.
    I have heard stories of the trigger ring spinning on the crank, but I know of 2 high output cars revving over 9k rpm with no reported issues so can only assume problems are down to the specific installation / installer.
    • adampug11
      • Sep 2017
      • 85
      Great cheers !
      Does the trigger ring just slip over the end of the crank flange? Hard to tell from pictures online.
      If I could have a lend of your tool I would appreciate it ! Is the installation tricky?
      Im not quite ready for it the cranks away to be balanced and the short block is not built up yet.
