Timing belt change
  • Mikes2
    replied
    Originally posted by riche164
    Air gun to open the bottom pulley mike it’s serious tight. 5 Cylinder timing belts are the easiest belt ever to to do why talk it up be be something complicated when it’s not !!!!
    And how do you torque it back up then Einstein. there is only one way to do it and it's not using air tools
  • LHD_Kid
    replied
    Originally posted by steve briance
    Maybe the air gun will get the bolt off but so will an angle grinder eventually. Doesn't mean it is OK.
    There is a seriously large number of upsetting stories around the audi forums of peoples engines being destroyed by failed crank pulleys. Why anyone would risk this for the sake of sorting the correct tool I don't know.
    Get the tool, get the 3/4 in drive breaker bar and probably a pole to slide over that to get the leverage and enjoy driving around in your car until the next belt change comes round.
    Its not difficult to do it right. and once you have the tools sorted, always have them for future use...
  • steve briance
    replied
  • Bowie69
    replied
    With a fragile pulley like on the I5, I wouldn't go anywhere near it with an air gun.
  • riche164
    replied
  • Mikes2
    replied
    Air gun for a timing belt ? Probably the worst advice I've ever seen on this forum. I have a locking tool that I'll be looking to sell as I sold my S2. Let me know if you're interested.. It's made by 4M
  • Bowie69
    replied
    Air guns are known for cracking the OE pulleys, which are weak as it is.
    I made my own locking tool in half an hour with a piece of pipe, a short length of angle iron, grinder and a welder.
    Well worth doing as you have it for next time.
  • riche164
    replied
    If you have a decent air gun you won’t need any locking tool. If your not changing the bottom pulley you don’t require any special tools just a bit of using your head
    replied
    I got all my parts from Autodoc. Just double check you are ordering the correct parts as after sales is CR#P
  • LSG
    replied
    Flippin Audi and the nla scenario. They do make owning one of their vehicles very trying. I could maybe help you out with the crank locking tool so maybe that's a help. Pm me if you like. Regards Lynn.
  • Chris5044
    replied
    Does anyone on here know where I can get a Special tool for cambelt change for my 1996 ABY?
    Also are those parts listed above still available? ie waterpump? etc.. and would I get them from the websites of those company names stated?
    Also when referring to a CrMo, do you mean the crank shaft pulley? and is this a modified one from Terrybullwon?
    Thank you,
    Chris (Looking at doing my cambelt change myself... (Atm Audi aren't doing parts anymore so its very difficult to source parts.)
    replied
    Excellent choice.
  • andy j
    replied
    Got my pulley today. Looks like a good bit of kit. I went with a Gates belt and an SKF water pump.
  • shorty_94
    replied
    Originally posted by Mikes2
    2084 doesn't work on the ABY. I fitted a Gates belt and Valeo water pump to mine
    Yes you are right! The pipe is too short for ABY engines, i forgot this.
    I had to modify my 2084.
  • Bowie69
    replied
    They are lovely aren't they
