I see there are slotted holes on the engine snub mounting bracket. From what I can see the bracket only has an up/down adjustment.
Does anybody know how to correctly adjust the snub mounting.
I fitted a new OEM rubber snub mounting when fitting an RS2 intercooler, I also fitted new engine and gearbox mountings.
Just need to make sure its fitted correctly before I close everything up.
