When I drive away gentle with light throttle movements and I lift the throttle especially when making gearchanges between 2.500 - 3.000 rpm there seems to be some noise. Maybe it occurs on other occasions to but this is when it is most notable. The noise is about the same as some water splashing to the wheelarches or like some slight airleak noise or maybe even something still rotating like an electro engine. Any ideas on this strange matter?
Little bit of noise in between gearchange
