tightening torque bearings crankshaft plate Epytec
  • tightening torque bearings crankshaft plate Epytec
    Hello
    Do you know the tightening torque of the bearing screws with the epytec reinforcement plate?
    Thx...
    Do you mean girdle plate?
      Yes..!!
      https://www.epytec.de/en/engine-and-...aan-adu-aby-3b
        It depends on the grade of fasteners
            Seems to be 12.9 grade bolts, so torque needs to be more that with 10.9 stock bolts(65Nm). I would go somewhere like 75Nm... Not more, so you don't deform the main caps. But you really would need to skim the shim bushes independently after measuring the block and girdle clearance.
              Thank you
              I will tighten them to 75 Nm
                Depends also very much on the thread pitch....
                  the thread pitch 1.50mm
                    hi
                    how did you seal the oilpump suction line between the girdle and the oilpumo?
