Running tial blow off and divertervalve same time
  • mllen89
    • Apr 2015
    • 63
    Hi
    i have a s2 3b. running maxxecu,
    want to put a tial blowoff on just next to tps.. do i have to remove the old divertervalve ?
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    why do you want to put a second one?
    if you fit a blow off it works fine on its own. You can delete the other one
    • piotr
      • Jul 2012
      • 1470
      I Tough that if you will fit blow off you must move your maf as other wise it will cause a problem
      • rxl
        • 1913
        with maxxecu you dont need a maf so whats not there cant be relocated.
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          exactly, aftermarket ecu doesn't use the maf
