Yeah, that was a stupid sugestion. I just had a quick peek under the steering wheel but couldn't recognize the relay numbers. - but they where all swapped except for the J341.
No updates yet, other than that PIN27 gets switched voltage as intended for a few days after I use the jumper cable between constant 12v and PIN27. But it dies without warning after a few days driving. Luckily I have the jumpercable in the loom and the ecu on the floor.
I have ordered all new relays and will swap to my other V94.
More to come, thanks guys!
Thanks! And a big thank you to Paul.
