Can someone please tell me what those two small holes is for?
Can someone help me?
Originally posted by Error404 View PostHoses pass through to the carbon canister behind the wing on the stock car
This gallery has 1 photos.
The cables in that area are potentially very important for engine running - MAF, WGFV to name a couple - hard to see what is burnt in the pic.
I dont know what the most technically correct / safest / eco-friendly approach would be to delete the carbon canister, but if I recall correctly its only used to treat evaporated fuel fumes from the tank - allowing them to be vented into (consumed by) the engine during overrun mostly. As I type this I realise I never spent any time looking at this little sub-system so apologies if I have it wrong.
My best guess at deleting the EVAP system properly is as follows:
- At the EVAP valve (N80) at rear of engine underneath inlet manifold - check there is no unmetered air going to get in - blank that hose off. If you unplug the N80 valve then it will raise a fault code on the ECU (unless it has been mapped out).
- Blank off the hose coming from fuel tank to the carbon canister.
Ah yeah - good clarification there Alex - one cannot block the tank ventilation (otherwise expansion of fumes on a hot day could get interesting in a bad way). I guess Audi decided it was more eco friendly to vent the tank into the engine via the carbon canister & evap solenoid... adding a bunch of extra pipes, more weight, the control valve and ECU involvement of course - an early step on the path to the bazillion lines of software and interconnected controllers in every modern day car.
The rear bumper vent location sounds ideal by the way.Paul Nugent
