S2 oem valve guides in uk
  • mac2226
    • Jun 2008
    • 1289
    I’m after some valve guides for my s2 where can I source some quick from uk please can audi still get hold of them?
  • SteveH
    • 4460
    Aren't they the same guides used on other audi/vw's? Should be easy to get from any machine shop supplier.
    91 Modded 3B
    14 A6 Avant Black Edition
    • mac2226
      • Jun 2008
      • 1289
      I’ve checked the size and some are 38mm long 7.00mm and 37mm long 6.8mm? I’m bit confused as to which ones I need I’ll check with my engineers tomorrow they might have a proper guide book with engine codes
        Be careful as many pattern guides are too large on the OD and distort badly on installation. Make sure your machine shop has the right broach for them too
        I use Mahle
        HTH
        • mac2226
          • Jun 2008
          • 1289
          I use Mahle
          HTH
          Alex yeah I think it’s best if machine shop order it for me and fit them I don’t have the broach to do job
          • Bowie69
            • Nov 2013
            • 2675
            IIRC they are the same as Golf 16V guides.
            Which makes sense given the 5 cylinder 20V is just a 16V golf engine with another cylinder tacked in place
            • mac2226
              • Jun 2008
              • 1289
              Cheers Bowie69 the machine shop I use can get the oem ones for me and yes I totally forgot it’s same as golf16v as they share same sensors as well I believe
