Air intake temp sensor fault
  • terrybullwon
    • Mar 2006
    • 8782
    Not having a much luck with the car at the moment
    Latest problem Is a fault code
    1 Fault Found:
    00523 - Intake Air Temp Sensor (G42)
    30-00 - Open or Short to B+
    I read a thread by stu (4 wheeldrifter) but its inconclusive
    I messured the across the two terminals on the sensor and got a reading of 520 so the sensor is not a fault.
    Where do i go next?
    Cheers James
    Chef
  • s2dude
    • Nov 2005
    • 1631
    Re solder the joints at the end of the two terminals.
    I had the exact same fault and the solder had dried out and cracked where the wires are soldered on to the sensor.
    Definately worth doing before you do anything else I would say. Then test the wires for continuity if that doesnt work...use s2 central maybe for wiring diagrams to find where they terminate?
    • terrybullwon
      • Mar 2006
      • 8782
      I will just go and do that, thank you
      Chef
      • terrybullwon
        • Mar 2006
        • 8782
        Spot on!
        A big thank you
        Chef
        • s2dude
          • Nov 2005
          • 1631
          Originally posted by terrybullwon
          Spot on!
          A big thank you
          Glad to be of assistance mate
