4032 pistons and cylinder bore
  • AndyP
    • 6049
    Originally posted by A80Avant
    It's a stroker with 95.5 crank so I cant use original pistons. ( I would on a heartbeat if I could!)
    You could if you used the tall block
    • Thuppu
      • 4115
      And 155mm rods.
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #33
        Andy isnt the diesel block already of a larger than 81.5mm bore? I was under the impression that all strokers used aftermarket pistons anyway.
        My other issue was that I already use a Wagner manifold with the phenolic spacer and there is no way this setup would fit under the bonnet. I would therefore have to buy new pistons,new rods, and inlet manifold perhaps the BST one which seems shorter.
        Perhaps I might in the future if I havent sold everything.
        The aim with this motor is the best power figure with the least 'likeable' lag. Given that my 3071gen2 is something I currently enjoy and it runs out of juice before 7000rpm I didn't mind building the stroker this way as it wont be a rev monster.
