Main caps from 16V to 20VT?
  • Main caps from 16V to 20VT?
    Hi guys, are 16V (ACE, 6A, KR) cam caps the same (dimension) as a 20VT (7A,3B, AAN) ? I missed 7A cam caps and i am not sure if i get it from the previous owner of the 7a head.
    Thanks,
    Audi Coupe Quattro 2.3 20V
    head without original cam caps is usually considered scrap. You would need to line bore, which is very expensive and makes it unviable (in most cases)
      Fitting replacement caps is costly - you need to skim the head and cap faces, then hone the cam bearing bores back out. It is a fair bit of accurate work and will cost hundreds of pounds/euros. Cheaper to get another head mate.
        **** Not good news, but thanks anyway guys
          maybe the previous owner can find the old caps.... good luck
            You know, he didnt answer the phone, he didnt react on messages, so its problem...
