hey guys . I have an Audi 7A Engine which has since been noted to 83mm and installed a 92.8 crank to make it a 2.5L 5 cyl 20v. I decided to go distributorless and install the 60-2 trigger wheel setup and CPS on the transmission end(crankshaft seal with trigger wheel trick), use the dizzy as a camshaft sensor and also install the Adaptronic e420d ECU . Problem is that I can not seem to get a cranking rpm and as such no ignition pulse . Could anyone give me an idea where my setup is going wrong ?i have attached my current trigger settings which give no output .
thank you in advance e
MONK
MONK
