RS2 spec PRJ chips
  • AquaS2
    • 705
    RS2 spec PRJ chips
    Is there a way to identify PRJ rs2 spec chips?
    Also what would I need to install them onto an ABY s2 with RS2 hardware?
    F I R E U P T H E Q U A T T R O
    1996 S2 coupe aqua green sold
    1990 MK2 Golf gti 16v oak green sold
  • twoqu
    • Sep 2003
    • 3103
    Assuming there is no external ID, one way would be to install them into the ecu and use VCDS to look at the ecu. Usually some info would appear in the relevant field. Another might be to put the fuel/ign chip into a programmer and essentially read the same info off the chip at the relevant address. Depends on what you have access to I guess. Would be a good idea to ID them as there is the difference between RS2/ABY software to factor in.
    • orsum
      • May 2010
      • 1213
      • Home: United Kingdom Current: South Africa
      I have never see my RS2/ABY chips or the ECU mods required to fit them so I cannot comment on what they look like but I can tell you that the Ross-Tech software indicates I have the PRJ stage 3 software.
      • prj
        • Mar 2010
        • 6308
        Yeah you can VCDS the ECU and if it's my SW it'll be tagged.
        • AquaS2
          • 705
          Cool, thanks
          • Canadian RS2
            • Oct 2009
            • 145
            Here's what VCDS displays when I scan my Engine Module with PRJ's chipset installed.
