Hello Guys,
Looking for some opinions on rod bearing wear. Rod number 3 has spun and the surface of the crank is rough.
Have checked all mains and they are like new.
Didint lose any fluids. oil and water levels/temp were good just heard knocking and then noticed low oil pressure?
I have the block all stripped down and wonder what is best to do? Am looking to save as much as possible and keep engine original if I can.
Any advice or suggestions much appreciated.
Damaged crank on the right and other rod shells have black areas.
Never good to see - was this a rebuilt engine? Shells tend to spin when there is not enough crush - i.e. big end bore is not sized correctly - too large.
