Turbo oil drain line
  • Costash
    • 878
    • Home: Romania Current: United Kingdom
    I am looking for precision turbo an12 oil drain fittings but I didn't had much luck. What you guys running on t3/4 stile turbos?
    If you have some basic dimensions of what you need, I can make you some:
    • Costash
      • 878
      Pmd
        Originally posted by Error404
        They're gorgeous - well impressed - again.
        • Pauliusb2
          • Dec 2014
          • 361
          Error how much is for 2 fittings like in picture?
          • stin
            • Jun 2010
            • 10
            Keep in mind that the female AN12 hose end might have problem fitting next to some compressor housings.
            • Costash
              • 878
              It is a bit tight but turbo is out and it is a bit easy. Fingers crossed.
                Those pictured were machined from 321 stainless and £60 each
                My "Standard" ones are machined from 6082 ally and £45 each.
                A lot of the cost is in the set-up time, for one-off machining - I could do a cheaper price on 10+ units if anyone else wants some I can price it up.
                The -12AN nut is 31.75mm (1.1/4") AF so in this application it looks like it will fit BUT must be fitted to the flange before installation, as you cannot turn the nut in-situ
                As Stin rightly says, quite a lot of turbos simply don't have the space for a normal -12AN flange fitting here, but I can machine something special to suit, with an extended neck)
                -10AN is perfectly adequate in most scenarios
