Well, I posted before and still have problems.
This cars spec;
Chipped
Garret T04E
Bosch 465cc injectors
Extractor exhaust manifold
3" DP
1,5bar WG spring
1,8t coils
Bigger ic
I bought this car after it had a fire in the cable harnesses. Most of the cables was connected to the MAF connectore, the rest im not sure of. Cut them and fuse everything together. Changes the hoses for the canister and cleaned everything up. Started the car and everything was fine except it was running fat and couldn't do more than 3/4 throttle. Maybe in limpmode? I found that the MAF also was burned - probably due the fire. Changed the MAF and it give me the right voltage. 1,5v with egnition on and around 2,5v when the car is idleing. Ride when I give it more throttle.
Still the car is running very rich, but when I disconnect some vacuumhose in the back in inlet manifold the car is running better. Put back the hose and the car runs ok, but still a bit rich. Disconnect the O2 sensor don't do anything at all.
Have pressuretest the susyem twice and can't find any leaks.
Can someone give me some hints please, this make my hair goes grey
This cars spec;
Chipped
Garret T04E
3" DP
1,5bar WG spring
1,8t coils
Bigger ic
