Identify these sensors/switches
  • Efini
    • 154
    • Home: United Kingdom Current: United States
    My order came in unmarked boxes so I'm gonna need some help identifying these:
  • GT500
    • Jun 2006
    • 2181
    1 and 6 are oil pressure senders
    3 is water temp sender (back of head)
    4 is rad fan switch
    2 is water sender in water rail under manifold
    Not come across 5?
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • Efini
      • 154
      4 is rad fan switch
      Not come across 5?
      Thanks a lot!
      Now that you have identified all but one, the only one that's missing on my order is the switch for the reverse light. Guess that's number 5 then.
        How much was the reverse light switch and what was the part number please?
        • Efini
          • 154
          I don't have the part number, so I can only tell you what I can read from the markings on the switch itself; 6099 03J
          Paid about £7 for it.
            Thanks!
            • topsparky
              • Oct 2005
              • 2014
              4 is rad fan switch
              Not come across 5?
              is n't no 5 the mfts (3 pin version )
              if it is get a 29 mm deep socket to fit it makes it a lot easier
              1. SHORT SHIFT KIT
              2. PORSCHE CAYENNE CALIPERS
              3. H & R SPRINGS
              4. BILSTEIN SHOXS
              5. NEW BUSHES AND HP2 STRUTS
              6. UPRATED HIGH OUTPUT COIL PACK
              7. ,3" turbo back s/s/ exhaust
              8. fmic fitted
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Number 5 is definitely the reverse light switch. I had a brand new one snap off inside the gearbox. I'll never forget what it looks like after that!
                SS
                • topsparky
                  • Oct 2005
                  • 2014
                  i'll get me coat then
                  1. SHORT SHIFT KIT
                  3. H & R SPRINGS
                  4. BILSTEIN SHOXS
                  8. fmic fitted
                  • john881000
                    • May 2004
                    • 598
                    NO 5
                    THINK its reverse light switch
                    CHEERS
                    JOHN
