Twin Dump Valves
    Twin Dump Valves
    I know a couple of members are running twin dump valves. Has anybody got any close up pics of the setup / pipework?
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    At least one has - with the most beautiful 80q ever built. Even pics of two stages (I assume that was not the best idea locat bov's near TBV).
    Development:
    Then he got rid of the MAF (moved to pressurized side?)
    Final version:
    Sau
      Thanks hmm not going to be easy but gives me nice ideas!
      • Keeper of The Kitten
        • Dec 2003
        • 2317
        What's the reason for / idea behind running two BOVs / DVs instead of one?
        __MDC__
        Martin Cutting
        • Ross
          • Aug 2005
          • 3399
          I'm hazarding a guess that this to eliminate the risks of turbo-stall when you're running high boost pressures? I suspect if you can't get rid of all that air quick enough, it'll push back against the compressor turbine which is an issue. Two DV's helps 'dump' the excess on lift-off before this occurs.
          Anyone got a 'real' answer?
          Ross
          • BrianSmith_S2
            • Jun 2005
            • 1342
            • Home: Northern Ireland Current: British Antarctic Territory
            Ross
            But he seems to be running with two pairs of std dump valves (4 in total ) see last two pics.
            Brian
            • Graham
              • 1622
              The last pic has them plumbed in before the pressure system though on the suction side of the compressor
                Ross
                Correct it also goes back through the MAF.
                Hence why power boys go for 50mm BOV to remove more air
                • jogi730
                  • 2335
                  I once asked my tuner why people sometimes fit 2 dump valves. He replied because the first one they fitted would not be big enough. Please don't shoot me down in flames if there is more to it than that, but looking at it simplistically, it makes perfect sense.
                  Chris
                  Audi 90 quattro (Typ 85)
                  20v turbo conversion
                  • LHD_Kid
                    • May 2006
                    • 3695
                    The big power Jap stuff doesn't necessarily use 2 valves,
                    I will try and get some pics...
                      Chris
                      I aint seen a bigger recirc does he know of one?. I've seen big BOV / dump valves which dump to atmosphere though.
                      • jogi730
                        • 2335
                        Ah.... did not realise you meant recirculating - it just said dump valves. What size are you using? I will be in touch with him on Monday so will ask.
                        Chris
                        • jogi730
                          • 2335
                          Sorry Jamo, taken longer to get hold of tuner than I thought.
                          Biggest recirculating dump valve is about 5" (125mm) and is from a company called Sadev?
                          Hope this helps?
                          Chris
                            Well you learn something new every day! thanks Jogi
