I seem to have some problems with my waterworks and have had for some time. I'm currently topping up the system on a regular basis so it's time to ask for some advice and try and fix the problem.
I'm losing water from the cap and don't seem to be able to stop it, despite replacing the cap. Everything is fine until up to temperature. Then I end up with the cap leaking, sometimes until the expansion tank is completely empty. I've tried bleeding the system and this appears to be successful but it's not fixing the problem.
The system appears to be over pressurised but I'm not sure if this is the case. Nothing milky on the oil filler cap so no indication that the head gasket gone between water and oil.
Any suggestions gratefully received.
Thanks
Alistair
Thanks
Alistair
